95 Neon engine swapimpalass 11-23-2002, 02:22 AM I have a 95 Neon. Blew the engine. I'm doing a swap to a 95 DOHC. Other than the engine... what else i will need. Also as a second idea if the DOHC don't work... If I take a 96,97,or 98 SOHC engine and replace the cam with the 95 high performance, did the 96,97,or 98 will have the same hp. Did anybody knows the hp on 95,96,97,98 engines. My car was reallllly fast soo i want to keep it that way.:devil: dnkygirl 11-24-2002, 08:06 AM Try asking your question on www.neon.org in the tech forum.. there's no on here hardly..... Meganium_Man 08-24-2005, 02:40 PM Don't you mean http://www.neons.org ? das2123 08-24-2005, 09:12 PM I have a 95 Neon. Blew the engine. I'm doing a swap to a 95 DOHC. Other than the engine... what else i will need. Also as a second idea if the DOHC don't work... If I take a 96,97,or 98 SOHC engine and replace the cam with the 95 high performance, did the 96,97,or 98 will have the same hp. Did anybody knows the hp on 95,96,97,98 engines. My car was reallllly fast soo i want to keep it that way.:devil:DOHC's are 150HP and SOHC's are 132HP. The 95 cam is more agressive than the later years and Mopar even sold it as a performance cam later. This post should help you out. http://forums.neons.org/viewtopic.php?t=80202 das2123 08-25-2005, 08:52 AM Try asking your question on www.neon.org in the tech forum.. there's no on here hardly.....Actually it would be the Engine Swap Board...I have seen you over there there dnkygirl. Automotive Network, Inc., Copyright ©2012
