Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > Silverado
Old 09-11-2007, 09:02 PM   #1
hogster3
hogster3 Normal reputation
up-down,up-down,up-down shifting
I have a 2000 silverado 4.8 extended cab short bed pick-up with a shifting problem.
At 50 m.p.h., it keeps shifting up and down. It is only about 200 rpm difference, but it is annoying. Any speed above or below that it is normal.
I just noticed it when i put a flowmaster 40 on. The tack goes from 1500 to 1700, and back over and over.
Could this be a sensor of some kind? And if it is can I replace it myself?
Thanks for any help
hogster3 is offline   Reply With Quote
Old 09-12-2007, 08:07 AM   #2
silverado122775
silverado122775's Avatar
silverado122775 Normal reputation
Re: up-down,up-down,up-down shifting
In these trucks there is a low and high gear for overdrive. it is suppose to keep it from downshifting to third to help with MPG. so it sounds like a sensor like you said or something with the tranny.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs.
silverado122775 is offline   Reply With Quote
Old 09-12-2007, 06:48 PM   #3
dhughins
dhughins's Avatar
dhughins
i have a 2000 4.8 ext cab short bed also. about a year ago it started doing the same thing. 2 months ago had to replace tranny. it didnt give me an error code till 3 mths before it quit. it gave the p1870 code. tranny slipping. i got in it and lost reverse and 2nd and 4th. good luck.
dhughins is offline   Reply With Quote
Old 09-13-2007, 08:40 AM   #4
silverado122775
that sounds like a clutch when out in the tranny. I had a 1979 Monte Carlo that lost Reverse and 4th. Clutch went out
Old 09-13-2007, 09:27 AM   #5
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
One thing to heep in mind is the engine has to be running up to par for the transmission to work right.
Check engine tune up first.
Check for codes and run a scannner check on transmisson and engine?
Has the transmission ever been serviced.
How far back on the exhaust system was the flowmaster installed?
MT
MT-2500 is offline   Reply With Quote
Bookmarks
Google
Web AF
