Somthing That I Wanted To Asksketchmaster 09-11-2007, 07:06 AM Does anyone draw cars in adobe illustrator, and if so can i see some of your work ...??:runaround: SKETCH:naughty: Roboduck 09-11-2007, 09:18 AM I do most of my drawings in Adobe Illustrator.. many are posted in the AF. Roboduck sketchmaster 09-11-2007, 10:13 AM i saw some of your work roboduck and you have done some very good cars could you make a little tutorial on how to start, when you wan't to draw a car should i start with the wheels or somthing like that , i just bought the prog. and wan't to use it .... SKETCH sketchmaster 09-11-2007, 10:15 AM and i forgot too ask one thing do you use a tablet or du you do it all with mouse...??? Rothart 09-11-2007, 01:00 PM Here's one that I did recently completely in Illustrator. It is very time consuming and you should make sure to keep your layers separated as best as possible. As far as the mouse goes, I use a trackball mouse unless I need a faster shape or brush stroke, then I go to the tablet. This one was done completely with the mouse though. http://i63.photobucket.com/albums/h126/Rothart/Bug-copy.jpg Roboduck 09-11-2007, 01:05 PM Well, I don't do tutorials because I don't know how to do them (electronically). I suggest that after you do the sketch (or use an illustration ala Jerri), start with the body outline. I try and do the wheels last, and fit them to the car's size... order doesn't matter significantly because each part of the car I draw is on a layer, which can be arranged in front of, or behind another layer... like a hundred layers of transparencies. I also use the path to "cut out" the window openings from the body of the car. That allows you to do an interior layer, behind the body layer and it shows through the body layer. I use a Wacom tablet... I use to use a mouse, but the tablet is so much better. Good luck in your endeavor. Roboduck under18carbon 09-11-2007, 11:56 PM I've done car vectors using Illustrator for quite some time now and here's some of my stuff : http://tn3-1.deviantart.com/fs11/300W/i/2006/202/5/e/oO_Lamborghini_Gallardo_Oo_by_under18carbon.jpg http://tn3-2.deviantart.com/fs11/300W/i/2006/201/2/4/Pagani_Zonda_F_by_under18carbon.png And I have written a tutorial as well, and there you'll find the link for the original .svg source file as well: http://under18carbon.deviantart.com/art/Vector-Art-Tutorial-13451609 Dx_king91 09-12-2007, 02:12 AM Some nice work I try to work on this but I 'm not good at this Automotive Network, Inc., Copyright ©2012
