01 Regal 3.8 intake manifold???
J-Roc
09-10-2007, 10:57 PM
Hi all,
The engine is a 3.8L in an 01 Regal and I've got oil in my radiator! I've read up on these engines and they're notorious for the intake mani gaskets as well as the intake itself to give. I checked around the intake mani and its all wet, either from oil or coolant. I also did a compression check and they avg. 140-150 psi. I'm pretty sure the head gaskets are okay, so I plan to change the upper and lower gaskets, as well as the intake manifold. My question is this: Are the oil and coolant ports near each other in the intake manifold (close enough for oil to leak in the coolant)??? Thanks for any pointers all!!!
BNaylor
09-11-2007, 06:56 AM
Yes. Symptoms will vary. Oil in cooling system, coolant in oil or just either an external or internal coolant loss. Visit the Buick Tips & Maintenance forum which has some helpful info on UIM/LIM jobs.
