99 yukon slt - miss fire but not pulling codes.tulsa_bikertrash 09-10-2007, 06:10 PM Hey all, I have a 1999 Yukon SLT with 105,000 miles on it. The engine has a vibration at idle and sometimes misses and back fire during light acceleration but, it does not pull up any trouble codes with an OBD2 scanner. I replaced the fuel pump, fuel filter, and cleaned the tank about 3 months ago. Any ideas would be helpful. maxwedge 09-10-2007, 09:09 PM Welcome to AF, if this in fact a misfire, a full scan will reveal a pending code or you can view misfire counts on a high line scanner. 99_Yukon 09-29-2007, 12:50 PM Had similar problem, and the problem ended up being a bad distributor cap. There was a hair line crack allowing spark to jump across. master1printer 10-12-2007, 11:19 AM Had same problem on 98. Full scan revealed weak intermitent signal from crank position senser. I had already replaced cap button wires plugs at advice from shitty scan owner mechanic. Retired GM service tech. told me there was a lot of wiring problems and to check wires to sensor for being overly stretched at factory to save a penny. I ended up replacing crank sensor it and runs great. Automotive Network, Inc., Copyright ©2012
