Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 09-09-2007, 04:02 PM   #1
bmoore2031
bmoore2031 Normal reputation
4.3 low on power... ideas???
So I have a 94 4.3 4x4 w/ 170k on the clock... I has very little power and can't do 65 pulling my new trailer.... Its about used up so I don't want to put much money into it... any ideas for getting another year outta it without putting to much $$$ in it.
I"ve done a few things already
plugs wires cap and rotor
fuel filter and new pump too
It doesn't use much oil so I don't think its the rings...
Can I set the timing and maybe jack it up a bit on this truck?
Anyone have luck cutting off the cat? I was going to but it was gonna be hard to weld in the location it was...
Any other ideas?
bmoore2031 is offline   Reply With Quote
Old 09-09-2007, 04:22 PM   #2
taillight
taillight Normal reputation
Re: 4.3 low on power... ideas???
Sounds like it might be time to trade up to a truck with a larger engine.
taillight is offline   Reply With Quote
Old 09-09-2007, 07:12 PM   #3
777stickman
777stickman's Avatar
777stickman Normal reputation
The 4.3 is great for around town and on the road by itself, but is really marginal for any heavy towing.
As far as the timing, it's all controlled by the computer as long as the base timing is set properly.
Base timing on a '94 needs someone with the knowledge to step in.
"R57 3CAR" 210 2dr post. 420HP 355 F/I 4sp 3:42 posi. (Dale Earnhardt tribute done by me.)
75 GMC Vandura 3/4 Ton
78 Chevy K5 Blazer
98 Chevy K2500 Suburban LT/7.4
05 Dodge Ram 3500/Cummins (Wifes horse hauler)
777stickman is offline   Reply With Quote
Old 09-09-2007, 08:58 PM   #4
bmoore2031
Thanks for the help.. I know I need a bigger truck but I need more $$$$ before that happens.. Anyone know what the base timing setting is on this thing..
Old 09-10-2007, 06:06 AM   #5
bjlandt
bjlandt Normal reputation
You can try adjusting the valves. There is a procedure in haynes manual. Don't overtighten, or you'll end up with less power than when you started. Only go 1/2 turn, not 3/4 like the book says. Mine has 300,000 and lacks 350 power, but still going good.
bjlandt is offline   Reply With Quote
Old 09-10-2007, 12:39 PM   #6
bmoore2031
Could you hear the valves rattling a bit before you adjusted them? Mine doesn't seems to tick like it needs it.... but a good idea and free so I will try it
Old 09-10-2007, 07:18 PM   #7
777stickman
Check out this link ( I Googled this) for more info on timing procedures. Make sure to read all the posts fully. There is some good info in there. I might add that if you're not familiar with adjusting valves in sequence you should leave them alone. However, if you are familiar with the sequence then go for it.
http://groups.google.com/group/alt.a...36bd1aaa00d5cb
78 Chevy K5 Blazer
Bookmarks
Google
Web AF
