help a girl out!!! 1992 Shadow ES - starting problem
carolelynn27
11-21-2002, 07:41 PM
Car ran great....parked for the night and when I came out the next day...it wouldn't start.
It was not a dead battery or bad connection at battery. Lights work fine.
Car starts with clutch dump....
When listening to the motor and trying to start I hear nothing at all...no click no nothing.
Help me out?
What can I do to isolate the problem more....I dont have $$$ for a shop to do the work.
HELP,
Carole
Polygon
11-21-2002, 11:12 PM
It could be your ignition switch, try holding the ignition, perhaps for a minute or two. I had the same problem with my 1984 Daytona.
Norm Petersen
11-22-2002, 01:47 PM
:flash: Did you check for a bad starter relay on the driver's fender-well ??
(I think it should be a rectangular shaped silver unit) maybe faulty!!
Also could be a loose wire going to the starter/or just the starter has seen it's days. :o
Are the battery connections/cables good and clean ???
Polygon
11-22-2002, 05:23 PM
Yes, these are good things to check as well.
flyinlowstereofree
12-03-2003, 02:07 PM
check starter solinoid.
positive jumper wire to switch pole.
