1995 Dodge no heat problem
mxz600
09-08-2007, 09:58 AM
Any and all suggestions are welcomed guys. Here's what I have so far.
Heat does not blow hot air.
Both lines out of the heater core are screaming hot.
Replaced vacuum line from under battery tray to by the throttle body.
Does NOT switch from floor heat to defrost heat upon acceleration.
A/C blows ice cold air.
When defrost is selected and hot or cold position for thermostat is selected, blows ice cold air up onto the windshield.
Switches from floor, to defrost, to any combo of those two with the turn of the selector, just like it's supposed to.
Please help, it's cold enough in the mornings now to need hot defrost to clear the windshield.
Thanks,
Jay
taillight
09-08-2007, 10:10 AM
Temp door sounds like it is not working.
mxz600
09-08-2007, 11:22 AM
How do I check it and where is it at?
Thanks,
Jay
taillight
09-08-2007, 11:54 AM
Under the dash in the heater plenum. Sometimes called the blend air door. Should be a vacuum motor that moves the door. Look for the hose off. Right in front of the passenger.
mxz600
09-10-2007, 03:42 AM
Thanks, I'll start digging there.
Jay
Dodgeman45
11-18-2007, 11:29 AM
Same problem on a 99, is the temperature door vacuum or electrically activated on my model?
