Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Nissan > Skyline / Skyline GT-R > Performance
Performance Discussion about performance modifications and issues.
Old 09-08-2007, 03:42 AM   #1
tym2burn
tym2burn Normal reputation
R33 Rb25dett Fuel Pressure????
Hey everyone just joined up! I was wondering if any knows the fuel pressure a rb25dett should be running! Or what everyone else is running? I have just installed a rising rate fpreg on mine!
tym2burn is offline   Reply With Quote
Old 09-08-2007, 09:23 AM   #2
mmcleo11
mmcleo11's Avatar
mmcleo11 Normal reputation
Re: R33 Rb25dett Fuel Pressure????
You should be running around 44psi with the vacuum port disconnected.
N14 Pulsar
VQ35 conversion with major N/A upgrades, 6 spd FWD manual HLSD
18" Rims, big brake kit, Coil overs and freshly painted
Smashed Black VY SS Ute
The workhorse...
Twin turbo 5.7L LS1
Boyd Coddington 19" Turbine Wheels
AP Racing 4 Piston Brakes
Tein Coil over Suspension
HKS EVC 6 Boost Controller
PLX Devices DM-200 OBDII
Custom Front Mount Intercooler
mmcleo11 is offline   Reply With Quote
Old 09-08-2007, 06:32 PM   #3
tym2burn
Vacum port disconnected? What's the advantages of that?
Old 09-10-2007, 03:20 AM   #4
mmcleo11
mmcleo11's Avatar
The little vacuum hose that goes to the inlet manifold, it needs to be disconnected when setting fuel pressure, as manifold vacuum will alter the fuel pressure. Hence why a rising rate fuel pressure regulator actually works, as boost increases, it increases fuel pressure.
Set the fuel pressure to 44psi with the port disconnected, once you set it, reconnect the vacuum port and it will be safe to drive.
Also, have you upgraded your fuel pump yet, as the stock pump does not like excessive fuel pressure.
N14 Pulsar
The workhorse...
Twin turbo 5.7L LS1
Old 09-10-2007, 05:15 AM   #5
tym2burn
Thankz For The Info! A Great Help Cheerz
Bookmarks
Google
Web AF
