Gasket blew for my transmission (92 blazer)
rdeckert
09-06-2007, 04:48 PM
I own a 1992 Blazer. I need to replace the gasket for the transmission that's in the pan. The gasket blew out and there's tranny fluid everywhere. I know that when putting the pan back, a certain amount of pounds needs to be applied to each bolt and they have to be put in a certain order. That would be the info I need. If you know it, please help me out here.
P.S. Can a truck overheating cause a transmission gasket to blow? Or can a bad gasket (before it blows) cause a truck to overheat?
inafogg
09-06-2007, 06:02 PM
NO to both questions.As far as installing pan there is a proper torque not sure but 30 inch lb. But no sequence in bolts if u want tighten from middle out WHEN TIGHTING DONT OVER TIGHTEN & SQUASH GASKET this will cause leak
