Check Eng Light , No codesPlanenut43035 09-05-2007, 10:14 PM 2001 jimmy,2dr 4.3 auto 4wd, Hey my check engine light is on, but when i take it to auto zone it won't power up there code reader?!#@%$? What gives? taillight 09-06-2007, 08:48 AM The computer is noe sending out information. Could just be a bad connection with the ALDL or it could be a bad computer. MT-2500 09-06-2007, 10:00 AM Check fo 12 volt power and ground on ALDA test plug. MT Planenut43035 09-06-2007, 06:19 PM Check fo 12 volt power and ground on ALDA test plug. MT Anywhere special on the plug? And can i hurt the comp by looking for a ground? old_master 09-06-2007, 06:52 PM Did you check all of the fuses in both fuse panels with a test light? MT-2500 09-06-2007, 07:37 PM Anywhere special on the plug? And can i hurt the comp by looking for a ground? As Old Master said check all fuses and check for 12 volts on both sides. Pin 4 is ground. Pin 16 is battery power. http://www.troublecodes.net/OBD2/ Planenut43035 09-06-2007, 09:53 PM yep i did Automotive Network, Inc., Copyright ©2012
