Re: P1345 Code and Rough Idle
Hello,
P1345 is crank position sensor/cam position sensor.
"white smoke" is coolant going out the tailpipe. If you saw this AND had bubbles in the oil, I would think the head gasket was leaking. To check this, you'll need a compression tester and get the compression readings from each cylinder. Any big variation in pressures will identify the culprit. Usually bubbles in the coolant is telltale of head gaskets also. In combination, the temp running higher and the rest of the symptoms point to mechanical problems possibly.
Hope this helps!
