Which engine is in the Stanza?grncivicdhr 11-20-2002, 05:55 PM I see that the 90-92 Nissan Stanza has a 2.4 liter engine. Is it the K24 engine that is found in the Nissan 240sx? Also is an sr20det bluebird swap possible with the stanza? Xerxes 01-28-2003, 10:28 PM the stanza has a ka24e, where the 240 SX has a ka24DE. which is just a rear-wheel drive version. if you want a sr20det motor, you basically need a custom made fit. and then your stanza may need to be converted into a RWD. its a tough thing...but it can be done:bloated: grncivicdhr 03-08-2003, 08:04 PM i found fwd sr20det'd at ARDperformance.com. it says it fits a 95+ 200sx but i'm sure it drops right into the stanza too sine the sr20 and ka24 have the same mounts Dillweed 04-16-2003, 09:17 PM Yeah you could do that but it's alot of hassle cause the wiring is way different. If you dump an SR20DET into an SR20DE powered car the only wiring that don't plug in is the AIV harness that you just tape to the injector harness. It's too easy. My cousin's doin' it right now. SR20DET into a 91 NX 2000. Automotive Network, Inc., Copyright ©2012
