Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Corsica
Old 09-04-2007, 06:08 PM   #1
cheech3456
cheech3456 Normal reputation
fuel injectors, 96 corsica
hello, I am needing to check the fuel injectors, could anyone tell me were they are located, or if there is a place that could test them. Thanks
chevy corsica, v6, 3.1 liter 1996
cheech3456 is offline   Reply With Quote
Old 09-05-2007, 09:17 AM   #2
taillight
taillight Normal reputation
Re: fuel injectors, 96 corsica
With a fuel pressure guage and a scan tool that will read live data you can test the fuel injectors in a round about way if you know how to use them. Other wise you have to take them out and have them tested at a place that tests fuel injectors.
taillight is offline   Reply With Quote
Old 09-07-2007, 04:29 PM   #3
richtazz
parts monkey slayer
richtazz's Avatar
richtazz +50
The injectors are located in the lower intake manifold, below the upper plenum (the part with 3100 cast into it). You'll have to remove the upper plenum to gain access to the injectors. The only "test" you can do is a balance test. Take a multimeter set to ohms, and check to see if the injectors are all close to the same resistance. Any that are way off from the others are suspect. A dead shorted injector can cause a loss of injector pulse and a no-start situation. There's not an exact resistance specification, because as they age, an injector's resistance will change.
Would you drive any better with that cell phone up your ...?!
richtazz is offline   Reply With Quote
Bookmarks
Google
Web AF
