2002 Ram A/c blower only works in highSAFARI_MAN 09-03-2007, 01:27 AM A/c light only comes on and blows cold air when in hi position. Is there any resistor pack on this system? Any advice will be greatly appreciated Thanks :banghead: rockwood84 09-16-2007, 12:21 AM yes and i m not sure where it is . but if its in the dash the whole dash gotta come out to get to it. look around on the firewall should be a 6 or 8 wire plug and the resitor bolts to the firewall. i you think you found it unplug it and see if blower works on high if it doesn't then replace the reistor if it still blows on high then it ain't it and keep looking. davesclassicauto 09-20-2007, 09:28 AM accessable from inside the truck, pass. side under glove box. SAFARI_MAN 09-20-2007, 07:49 PM I will try that this weekend. Thanks guys:wink: rockwood84 09-21-2007, 02:55 PM think a '96 ram a/c resistor would be there also? davesclassicauto 09-24-2007, 09:08 AM Same area,,, rockwood84 11-23-2007, 03:07 AM Same area,,, thanks Automotive Network, Inc., Copyright ©2012
