98 buick regal wont start
kp911nana
09-02-2007, 07:55 PM
I have a 98 buick regal that wont start, all the dash lights, headlights, fuel gauge and radio etc, work when i turn the key but nothing else, any ideas?
BNaylor
09-02-2007, 09:11 PM
Welcome to AF.
What about the SECURTY light? On or flashing?
kp911nana
09-02-2007, 09:38 PM
Welcome to AF.
What about the SECURTY light? On or flashing?all the dash lights come on when i turn the key and then go off except the check engine soon light and the oil pressure light, just had complete service done last week
kp911nana
09-02-2007, 10:12 PM
all the dash lights come on when i turn the key and then go off except the check engine soon light and the oil pressure light, just had complete service done last weekis it possible it could be ignition switch?
BNaylor
09-02-2007, 10:24 PM
Possible since it is a common failure item. Does it not start in neutral and park? Also, you can check the 12 volts at the starter solenoid "S" terminal when ignition is set to start.
kp911nana
09-02-2007, 10:44 PM
i tried that, it will not start when in neutral, i did hear a faint hissing noise whenever i turn the key but then it goes away, we checked the ignition fuse but could there be others that could be a problem, i see several fuses related to the ignition in my owners manual
richtazz
09-04-2007, 06:48 AM
Are you saying the starter does not engage to turn the engine over or does the car crank over but not start?
kp911nana
09-04-2007, 10:24 AM
the starter does not engage to turn the engine over, nothing at all happens except the dash lights come on like they usually do but nothing else, no clicking sound, nada, i still have full power to the car though
richtazz
09-04-2007, 11:22 AM
will it jump start? Check the battery (under a load test) and all connections at the battery. If the battery is weak, or the terminals are loose or corroded, it can allow low amp current through to run the lights, radio, etc..., but not the high amp current necessary to allow the starter to turn over.
Did you test for voltage at the "s" terminal on the starter solenoid when the key is in the start position as Bnaylor suggested?
