Re: A/C conversion
Yes: don't convert to R134a, and don't use any sealers or so-called "freon substitutes". It uses a different type of oil, and yours is filled with mineral oil for use with R-12 (most stays in the system even if the R-12 leaks out. You live in Florida, need all your cooling, and R-12 will work better. R-12 is still available, even plentiful, not cheap, but yours only takes 2 pounds, cheaper than a so-called "conversion". You can also purchase R-12 yourself, but first you need to get a 605 certification, about $25 through the Internet. When's the last time you had R-12 added? If you have a real slow leak and haven't added any refrigerant in a few years, that would be "normal" and you may just need one can to top it off and last several years. Have you read your AC pressures? My '88 B2200 is still R-12, in Arizona.
