Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 08-29-2007, 05:15 PM   #1
cash_75063
cash_75063 Normal reputation
mid 90s ECU wiring diagram
Hi guys. I hope someone here can help me.
I don't have a Cavalier. However, I am using a couple of mid 90s Cav throttle bodies on my 1965 Corvair that I am putting fuel injection on. I don't have the thottle bodies in my hands at the moment, but I need to figure out if I can use the ECU for air/fuel control on this mod. I can pick up an ECU at a salvage yard or at a dealer, but they aren't any help on wiring. I'll pick up a repair book when I get home tonight, but mostly I think I'll need to know what wires are essential to get this functional. I expect there will be a lot of unused pins on the connector.
Thanks in advance-
-Cash
cash_75063 is offline
Old 01-25-2008, 09:51 PM   #2
anomaly_va_1976
anomaly_va_1976 Normal reputation
Re: mid 90s ECU wiring diagram
You don't mention if they are TBI or MPI style... but you can use a factory style ECU... better to get it all from the year model the TB came from.... good luck, you're going to need it. I see your main problem being getting the ECU to trigger the injectors, as your Corvair does not have a crankshaft sensor... You may be able to use a flying magnet trigger setup to do this, but I don't know if it's the same type of signal.
Most 90s GM cars are the same as far as the ECM control schematics go....The schematics for different models are available in most Haynes Repair Manuals for each body-style manufactured -- again, make sure that you get the schematic for a TBI or MPI setup according to what you have.... TBI would apply to late 80s-early 90s Cavaliers/Corsicas/Berettas/Sunbirds, and some cars that had the 2.5L.... MPI would apply to most 86-later 2.8s and 3.1 and 3.8s. One other thought that might help..... The pre-87 2.5s had a distributor with TBI, this may be a possible donor system that would work.... BUT.... IIRC, the Corvair was based largely on a Porsche/VW engine setup, I wonder if swapping an FI system from a later boxer-style enginewould be easier? Also consider that Ford (AGGGH, I know) used a twin-injector, single TB setup with dual oxygen sensors for 1987 ONLY, on their 3.8 V6, in T-Birds and the like.... Those engines are known to blow up quite a bit and could be a possible swap, an 88 could be utilized the same way, but they are MPI and only use one exhaust sensor.
Good luck!
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < anomaly.va@gmail.com >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
anomaly_va_1976 is offline
Old 01-25-2008, 11:16 PM   #3
'97ventureowner
'97ventureowner's Avatar
'97ventureowner Normal reputation
Please do not bring up old threads beyond 90 days since last activity. Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline
Closed Thread
Bookmarks
Google
Web AF
