I am pretty sure that I know where they are but it looks like I have to take off a plate and want to make sure I am right. Can someone tell me where they are located and how to get to them? Its a 97
Spark plugs are located in the center of the valve cover, run the length of it. Just remove the plug boots and use a socket to remove them. It should be a 16mm socket. Make sure it (socket) has the rubber insert so the plug doesn't fall back down when you get it loose. The correct gap is .043 and torque is 13 foot pounds.
