Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 08-25-2007, 12:35 PM   #1
papa chevy
papa chevy Normal reputation
no fuel or spark
this is my dillema. 97 astro awd,no fuel signal-new pump installed.Can fire pump with primer connection under hood,but the injectors don't fire either. It has no spark to the wires.I started with checking fuses,both under hood and dash.Ichecked grounds,in front of the fuel tank,on the stat housing,several under the hood.Cant find under dash.Where are they?Iwent as far as trying a different computer(below the batt.)Replaced the distributor.Seems to give signal from ignition control module(pulses) I am getting pulse at the crank sensor,as well as power and ground. The fuel gauge is now stuck over full. I am wondering what the common link between these is.I haven't found any fusible links in this system also. where are they at? I will be checking in often if you need any more info. From my browsing this website,you seem to be extremely helpfull,as well as intelligent. I hope that you can help 'cause I'm pulling my hair out now!!
papa chevy is offline   Reply With Quote
Old 08-25-2007, 03:06 PM   #2
ericn1300
AF Premium User
ericn1300's Avatar
ericn1300 Normal reputation
Re: no fuel or spark
do you have a security system on it?
ericn1300 is offline   Reply With Quote
Old 08-25-2007, 11:07 PM   #3
papa chevy
It used to have an aftermarket system on it, but I removed it 3 years ago. I even thought about the factory VATS system,but doesn't that also disable the starter?
Old 08-29-2007, 08:41 PM   #4
old_master
Advisor/Moderator
old_master's Avatar
old_master Normal reputation
Fuel gauge will read over full when the fuel level sender loses ground. Could be an open circuit in the sender itself, or it could be a bad ground for it.
Fusible links are under the underhood fuse panel. Follow the fuel pump prime wire back, you'll find them. Fairly common problem for the connections to corrode.
old_master is offline   Reply With Quote
Old 09-13-2007, 10:12 AM   #5
*TORCH*
*TORCH*'s Avatar
*TORCH* Normal reputation
try a proffesional tuneup...mainly sparkplugs and wires..did u try a new battery..
*TORCH* is offline   Reply With Quote
Bookmarks
Google
Web AF
