Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Closed Thread Show Printable Version Show Printable Version | Email this Page Email this Page | Subscription Subscribe to this Thread
Old 08-25-2007, 12:28 AM   #1
doberman_52
doberman_52's Avatar
doberman_52 Normal reputation
Send a message via MSN to doberman_52
Engine probs, 92 cav
My 92 Cavalier RS won't start. Put in a brand new fuel filter, old one spit out black gas. Checked the timing, spark, and compression, compression was at 125 at the weakest and round 165 at the best and 145 for the other 2 I think. I don't know about fuell pressure yet but should have that tested by tuesday at the latest. We sprayed some starter fluid in it while cranking and still nothing happened. When it first died, I was driving and it shut off and wouldnt start right away. About 5 minutes later it would start but died when it got revved a little bit, but started back up and seemed to be fine later on. Later when i left work, got a few blocks away and it died, same thing. Next day it backfiered a few times and now it just cranks but wont fire. It is the 2.2L ad has 200k on it and I cant afford a new car. Any ideas would be appreciated
1994 Chevy Cavalier RS - 2.2L I/E
Cory
doberman_52 is offline
Old 08-25-2007, 10:05 PM   #2
doberman_52
Re: Engine probs, 92 cav
Would a crank position sensor do this?
Cory
Old 08-25-2007, 10:15 PM   #3
ChemMan
ChemMan Normal reputation
You said that you sprayed starting fluid in it and the engine did not fire correct? That tells me to check for spark.
1995 Buick Lesabre Custom 73000 miles
2002 Pontiac Sunfire SE 103000 miles
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
FTN
ChemMan is offline
Old 08-25-2007, 11:36 PM   #4
doberman_52
It has good spark. Took them out and laid them on the block and they were a good strong blue spark.
Cory
Old 08-26-2007, 09:34 PM   #5
doberman_52
Crank position sensor isnt it, any ideas?
Cory
Old 08-27-2007, 06:12 PM   #6
ChemMan
So far you've verified that you have spark, but you haven't fully verified fuel yet. What is the fuel pressure at the rail? If pressure is good, then you need to verify that the injectors are being fired by the computer. Get the car scanned for codes.
FTN
ChemMan is offline
Old 08-27-2007, 11:37 PM   #7
doberman_52
Im bringing it to a shop tomorow nite to get the fuel presssure read, that has to be done by the filter since it has botom feed throttle body injection, i will also see if he will check the injectors if its good, my dad had a scanner hooked up and he said it found nothing but that may also be that he really doesnt know how to use it...
Cory
Old 08-29-2007, 09:57 PM   #8
doberman_52
Finally got it to a mechanic today, he is going to do a scan and fuel pressuer check and see if he can find the problem, im tired of messing with it for the past 3 weeks
Cory
Old 01-25-2008, 09:48 PM   #9
anomaly_va_1976
anomaly_va_1976 Normal reputation
Just my .02 worth....
My 93 Beretta had similar issues when I bought it... it would not start unless I opened the throttle. Turned out to be a bad ECM--- it was loading up at idle, not allowing it to start.
Don't Worry What Others Think -
They Don't Do It That Often!
James Collier < anomaly.va@gmail.com >
1992 Chevrolet Cavalier Z24 Convertible (3.1, 5-sp) *** FOR SALE -- SEE CAVALIER CLASSIFIEDS ON AUTOMOTIVE FORUMS.COM***
1993 Chevrolet Beretta (3.1, 3-sp auto)
1995 Mercury Marquis (Taxicab, i.e., breadwinner)
anomaly_va_1976 is offline
Old 01-25-2008, 11:17 PM   #10
'97ventureowner
'97ventureowner's Avatar
'97ventureowner Normal reputation
If you have new info to add, please start a new thread rather than resurrect an old thread. Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline
Closed Thread
Bookmarks
Google
Web AF
