2002 grand prix electric probdave6558 08-24-2007, 04:41 PM I have a problem with power going in and out to all accesories interoir and headlights. airconditioning,radio,computerfuel display, even the headlights go out at times and come back on without even moving the car. its not all at once either sometimes its just the air and other times its radio and air out. Just seems to be no pattern at all to help. The motor always runs perfect. I have checked battery cable grounds,motor ground, loose wires where i can see them at least and it is showwing no computer trouble codes so far. I know the list is long here but im hoping someone else has seen this before or atleast give me your opinion. It has been to a local diagnostic shop andthey couldnt find anything even with the problems happening right in front of them. thanks dave richtazz 08-24-2007, 09:29 PM Your problem is most likely a faulty ignition switch/harness. Here is a link to the replacement proceedure if you want to attempt it yourself http://www.automotiveforums.com/vbulletin/showthread.php?t=653340 Automotive Network, Inc., Copyright ©2012
