Intrepid 99 overheating with A\CPablo1479 08-22-2007, 05:53 PM Hi, I have a Intrepid 99, 2.7 Lt, when I drive for around 30 min in a city without the A\C the car terperature is normal (middle); then when I turn on the A\C and I drive for 15-20 min, the temperature increase to full. I change the water pump and the thermostat, and add antifrezzer. And the problem continuous. Someone have any idea for this problem. taillight 08-23-2007, 10:04 AM When you turn on the A/C does the cooling fan come on at the same time. It should. Pablo1479 08-23-2007, 11:53 AM yes the cooling fan start when the A/C is on. But I don't know if they start at hi or low... sbarr3 12-20-2007, 09:12 AM I'm no help to your question, but maybe you could be help to me. I am trying to change the thermostat in my 98 intrepid and the housing on top of the motor seems to have a long metal pipe that runs along the inside bottom of the heads? How do you change the thermostat in these cars? Pablo1479 12-20-2007, 10:56 AM Ok, you can change the thermostat in the housing of the thermostat between the motor and the alternator, you need to take out the alternator to full access to the housing :grinyes: Automotive Network, Inc., Copyright ©2012
