excessive headlight burnout
19hole
08-22-2007, 03:23 PM
2003 trailblazer ext having to replace headlights almost every 3 to 5 months
normal ???
maxwedge
08-22-2007, 04:14 PM
Welcome to AF. PITA, I have the same issue with my 2002. The Sylvania Brite Blues burned out every 7 months. Even melted the connectors. I Went back to std bulks, soldered in HD connectors from NAPA, still some issues, took the covers off the back of the lamps to allow more cooling. Check your grounds also, this can ciuse high voltage, also check inside the lamp connectors for signs over overheating.
19hole
08-22-2007, 05:35 PM
thanks,for the reply will try the same thing
taillight
08-23-2007, 09:52 AM
Check your running voltage. Your voltage regulator may be over charging.
Jethro
08-23-2007, 10:21 AM
Im still on my original lights from back in 2001
geknapp
12-13-2007, 01:10 AM
normal ???
I have a 2004 TB and am having the same issue. I have also noticed that my volt meter drops to about 8 volts after letting off the gas during cold weather. After some research I have heard that the TB's have a secondary smog pump that is supposed to work only during startup but can and does kick in after startup during cold weather. This is a huge strain on the alternator and electrical system. I am wondering if this draw is causing premature failure of the lights and who knows what else.
maxwedge
12-13-2007, 04:50 PM
Welcome to AF, you have tagged onto an old thread, please start a new one, thanks.
