electric mirrors work only one direction?
phil a
08-21-2007, 02:30 PM
The wifes Van 04 ,has the tilt down mode,, but locked up after that,,
you can switch from either side its the same,, you can hear the motors running in the mirror housings,, it s odd both would go bad at same time on different sides.. any clues out there.? thanks for any replys....
garync1
08-25-2007, 08:38 AM
Not sure if this will work but has in the past on other cars. Roll down the window and while using the controls push a little on the mirror in the direction you want it to go. Sometimes they get stuck if you put them to far in one area.. Just a thought.. Hope it helps... Gary
2010BIGFOOT
09-08-2010, 05:57 PM
The mirror switch on the door is corroded. Snow and water fall right in to it when you open the door in bad weather. You can remove the switch and open it up by prying open the two retaining clips. Open the switch and you will be able to lift off a rubber pad that has several copper contacts glued to it. Simply spray clean with contact cleaner from radio shack. Also spray the circuit board contacts that will be easy to see. I also used a q-tip to agitate the cleaner before it vaporized but go easy if you do this. Let it dry, put back together and re install. The bottom line is it works and saves the cost of a 30.00 part.
Dan_J
10-04-2010, 02:54 PM
Thanks for posting this. I have the same problem (amongst others). Mirrors move up and down but not side to side.
Edit: Fixed! I can cross this one off the list.
