Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > Legend/RL
Old 08-21-2007, 11:43 AM   #1
tynitti
tynitti Normal reputation
Question Acura RL 2003 keyless remote
Hey does anyone know how to program the keyless remote for a 2003 Acura RL. I recently bought the car and they gave me a new remote without instructions and said i would have to go to the dealer to have it programmed. The only problem with that is they will probably charge and hourly labor rate for 5 minutes worth of work. Please help
tynitti is offline   Reply With Quote
Old 08-27-2007, 05:24 AM   #2
Onblsht
Authorized Vendor
Onblsht's Avatar
Onblsht Normal reputation
Re: Acura RL 2003 keyless remote
Do steps 1 - 12 on the same remote (AT TIME OF PROGRAMMING BOTH REMOTES MUST BE PRESENT SINCE THEY WILL NOW BOTH HAVE TO BE REPROGRAMMED.) The following steps 1-12 are done on a single remote step 10 is done on all remotes to be programmed up to 4 can be programmed
1) get into the car shut the doors (including trunk or tailgate) and make sure they are unlocked
2) turn on the ignition (do not turn on the engine just the ignition til the dash lights come on) (LISTEN FOR A QUIET CLICK)
3) press the lock button on remote (turn to off) (Do not remove key)
4) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
5) press the lock button on remote (turn to off )
6) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
7) press the lock button on remote (turn to off )
8) turn on the ignition (do not turn on the car just the ignition) (LISTEN FOR A QUIET CLICK)
9) press the lock button on the remote
the locks should cycle to indicate that programming mode was entered successfully
10) press the LOCK button on each remote you want programmed and the door locks should cycle again to confirm programming. THIS STEP NEEDS TO BE DONE FOR EACH REMOTE
11) turn off the car fully and remove key.
12) try locking/unlocking with remote to test
to turn on/off the chirping when locking/unlocking with remote do the following
press the trunk release button on the remote and hold it then while holding press the LOCK button on remote and hold it the led on the remote will flicker for about 1sec after it goes off release both buttons and test it the procedure for chirp on and chirp off is the same, this needs to be done on both remotes otherwise only the one programmed will allow chirping while the other will still be silent or vise versa
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Onblsht is offline   Reply With Quote
Bookmarks
Google
Web AF
