Wiring diagram1357403 11-16-2002, 07:13 PM Can anybody tell me where i can find a firing order diagram of a 94 3.3 ltr Caravan? I changed the thermostat and might have screwed the wires up because it wont start. Please help rduke 11-17-2002, 12:09 AM Mine is a 97 3.3L but I used to have a 91 3.3L also and there is not too much difference between the two except that the newer one's have very little space for you to work in. The new belt tensioner seems to break a lot too compared to the old one. Firing order 1-2-3-4-5-6 The 6 terminals on the ignition coil box are labeled, but you need a flashlight to read the numbers. Number 1 on the ignition coil is the top middle so they are not in a logical order. The spark plug wires are numbered. The spark plugs/cylinders should be 2-4-6 in the front and 1-3-5 in the back. Number 1 and 2 are the left most when facing the engine from in front of the car. Don't forget to reconnect the control cable to the ignition coils if you moved it. Good luck Automotive Network, Inc., Copyright ©2012
