Cobra MAFty423 09-19-2001, 03:15 AM Now...how does this work....just rewire and drop in??? will it read the same as the oem??? do you need to redo the ECU??? please explain someone...and where do you place it??? before Turbo or after??? P10DET 09-19-2001, 11:16 AM Originally posted by ty423 Now...how does this work....just rewire and drop in??? will it read the same as the oem??? do you need to redo the ECU??? please explain someone...and where do you place it??? before Turbo or after??? You do have to reprogram the ECU to use a Cobra MAF. Whoever says otherwise is a monkey. The MAF goes before the turbo. ty423 09-19-2001, 04:08 PM thanks P10DET I can always count on you for good info... G-Forces 09-19-2001, 05:43 PM Originally posted by P10DET You do have to reprogram the ECU to use a Cobra MAF. Whoever says otherwise is a monkey. Or you need a piggy pack system like a TEC-II or Motec. But those are expensive. Basic Apex-i crap like the AFC. ty423 09-22-2001, 01:57 AM why you doggin AFC??? I know its cheap but I don't have thousands to spend on the expensive stuff and all that tuning...I just want alittle more power...Anyways thanks for the replies P10DET 09-22-2001, 09:33 AM Originally posted by ty423 why you doggin AFC??? I know its cheap but I don't have thousands to spend on the expensive stuff and all that tuning...I just want alittle more power...Anyways thanks for the replies Because it's a monkey method of tuning. Owners of some cars have little choice, except to go to a stand alone system. What are you doing that requires you to use a Cobra MAF? If you are making that much hp, you should already be spending thousands. You don't need a Cobra MAF until you're making over 250 bhp. To do that means you would have to have a $3k+ turbo set-up. If you're spending that much, now is not the time to go cheap on engine management. Get a JWT ECU. They are plug and play. Those black boxes are "Dial-a-Booms." If you screw something up, you could be in big trouble in a hurry. ty423 09-22-2001, 01:02 PM I am putting together a turbo kit for myself and read something about the cobra MAF...seems like it was required...and plus Jim Wolf doesn't do the P11 ECU yet...thats what I hear... P10DET 09-22-2001, 06:06 PM Originally posted by ty423 I am putting together a turbo kit for myself and read something about the cobra MAF...seems like it was required...and plus Jim Wolf doesn't do the P11 ECU yet...thats what I hear... What kind of turbo are you going to run? You won't need a Cobra MAF unless you put more than about 215 to the wheels. That will take a T3 or larger turbo. JWT can probably hook you up with a 97 ECU and wiring harness. That is what they did for their SEMA B15 turbo. G-Forces 09-22-2001, 06:12 PM Originally posted by ty423 why you doggin AFC??? I know its cheap but I don't have thousands to spend on the expensive stuff and all that tuning...I just want alittle more power...Anyways thanks for the replies Hehe, ;). Didn't mean to offend ya bro. You can get some good results from the AFC. It's not perfect, in fact I'll probably end up with one before I get my turbo. However with a turbo I'll probably go with JWT, even if I have to modify the harness to use the unit. Or the JUN if I can get more info on it. For tuning turbos I still maintain the AFC's and dial-a-booms, as George calls them, are crap. Just my opinion. ty423 09-22-2001, 07:38 PM yeah its all good...i was just kidding anyways...I am going to get a small turbo...only need to boost 7psi...don't want to do all the crazy stuff... anyways can I use a s13 or s14 manifold and turbo for my car??? please let me know...I am about to buy one... P10DET 09-23-2001, 02:42 AM Originally posted by ty423 yeah its all good...i was just kidding anyways...I am going to get a small turbo...only need to boost 7psi...don't want to do all the crazy stuff... anyways can I use a s13 or s14 manifold and turbo for my car??? please let me know...I am about to buy one... I don't believe you can use the S13 or S14 DET manifold. IIRC there is a problem with turbo placement and clearance. I'm not 100% sure about this, but some time spent searching the SE-R Mailing List archives would be time well spent. I know this has been discussed there and I seem to recall Mike Kojima addressing this issue. You might have to be patient in searching, but I'm 99% certain it was discussed. T4 Primera 09-23-2001, 09:22 AM While on the subject of ECUs, I've noticed that no-one in the US ever mentions the Dastek Unichip piggy-back computer. Is there a reason?, are they expensive there? Are the a POS? They claim that if you are not satisfied within 3 months they'll refund your money including installation and mapping costs. From what I've read they are a great concept and their site lists over 20 suppliers in CA alone. Heres a link to Dastek's Unichip homepage http://www.dastek.co.za/ P10DET 09-23-2001, 11:43 AM Originally posted by T4 Primera While on the subject of ECUs, I've noticed that no-one in the US ever mentions the Dastek Unichip piggy-back computer. Is there a reason? I don't think they are imported here. I've never seen them advertised or mentioned. T4 Primera 09-23-2001, 12:18 PM Originally posted by P10DET I don't think they are imported here. I've never seen them advertised or mentioned. I think it's a franchise thing cause they have to be dynoed to each individual car. List of US dealers here http://www.dastek.co.za/us_dealer_list.htm There are 7 in Texas and the following 2 in Houston. Hocus Pocus Houston TX 281-530-2206 hocus@hocuspocus.org www.hocuspocus.org Hou-Tek Vehicle Dynamics Houston TX 713-464-0053 white540i@aol.com T4 Primera 09-23-2001, 12:35 PM A bit more tech about it here http://www.dastek.co.za/unichip_dealership.htm P10DET 09-23-2001, 01:34 PM Originally posted by T4 Primera I think it's a franchise thing cause they have to be dynoed to each individual car. List of US dealers here http://www.dastek.co.za/us_dealer_list.htm There are 7 in Texas and the following 2 in Houston. Hocus Pocus Houston TX 281-530-2206 hocus@hocuspocus.org www.hocuspocus.org Hou-Tek Vehicle Dynamics Houston TX 713-464-0053 white540i@aol.com Wow. I'm not familiar with Hou-Tek, but I am with Hocus Pocus. Interesting. I can't tell you why no one seems to use them then. G-Forces 09-23-2001, 02:06 PM There is a guy here in Toronto that supposedly does the Unichip. I was going to try it out but they guy never got back to me. He had to check if they had an adapter for the G20. I probably scared him off because it wasn't a honda. :D Automotive Network, Inc., Copyright ©2012
