Fuel pump won't shut off
Cedarblues
08-18-2007, 01:30 PM
Had a dead battery couple days ago. Recharged the battery and discovered fuel pump keeps running after key is shut off and key is removed even. Any ideas ? Drove up the road a few miles and back. It runs fine but the pump will not shut-off. Unplugged the pump at the tank to determine this. Thanks for any and all help.
rnj
08-18-2007, 05:40 PM
Sounds like the fuel pump relay!
Cedarblues
08-18-2007, 07:45 PM
Update !!! Checked relays and fuses. Swapped them with known working ones. No change. Decided to change my oil and install new pressure sensor/switch which had been acting goofy. Disconnected battery and installed new switch. Reconnected battery and I did not hear fuel pump. Runs fine, good PSI and fuel pump shuts off like normal. Not sure of the connection or coincidence. Thank God. Thank Automotive forums and ACNA.:wink:
