Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 08-18-2007, 09:41 AM   #1
skulemowski
skulemowski Normal reputation
ignition or passkey
i have a 99 cavalier i have had problems with the passlock and ignition twice and i have taken it to the dealer and had it fixed twice. now its Messed up again but not like the first two times. the first two times it would start then the car would just shut off but we could still get our key out. now we started it and it did that again but we tried it again and it started however the a/c wasnt working nor was our radio, cooling fans and power windows. the car was able to drive however the key is stuck in the on position and we had to pull the fuel pump relay to get the car to shut off. the car acts as if it is not on and by some fluke the engine is running because if i press recall on my radio it tells me the time. WHAT IS going on?
skulemowski is offline   Reply With Quote
Old 08-22-2007, 09:55 PM   #2
skyline459
skyline459 Normal reputation
Re: ignition or passkey
look at the ground wire attached to the battery box remove the 13mm bolt holding the wire check for good contact ....good luck
skyline459 is offline   Reply With Quote
Old 08-22-2007, 10:18 PM   #3
Mangoamerican
Mangoamerican Normal reputation
Send a message via ICQ to Mangoamerican Send a message via Yahoo to Mangoamerican
sounds like your ignition is gone
Mangoamerican is offline   Reply With Quote
Old 08-26-2007, 09:55 PM   #4
skulemowski
thanks for your help guys. It turned out to be the passkey (lock). I had to go to the dealerrunaround again. They knew what it was right away. they should this is the thrid time in less than a year.
Old 08-27-2007, 06:14 PM   #5
ChemMan
ChemMan Normal reputation
Sounds like it's time for a new dealer too. Seriously, if they are incompetent, don't continue to support their business.
1995 Buick Lesabre Custom 73000 miles
2002 Pontiac Sunfire SE 103000 miles
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
FTN
ChemMan is offline   Reply With Quote
Bookmarks
Google
Web AF
