2001 Safari stalling at idle!wisemank 08-17-2007, 12:09 PM All, I have a 2001 Safari with 160k miles. The van runs great down the road until I stop at a light or sign etc.. Then intermittenly the idle drops and stalls. No problem starting, but at that point I am left to drive two footed. The gages drop also (oil pressure, alternator, fuel). As time goes on, it seems to be more frequent. Any thoughts where to start? Thanks in advance. Kip ericn1300 08-17-2007, 07:28 PM sounds like a clasiic EGR valve problem, but that would set a trouble code and turn on the check engine light during the problem. have you checked for stored trouble codes? wisemank 08-19-2007, 01:21 PM I am not getting a light, but I haven't checked for codes yet. Thanks I will update. Kip dadsafari02 08-22-2007, 08:47 PM I had a similar problem with my 92 Safari. I changed the throttle position sensor with no change. Turned out to be the EGR had a piece of carbon causing the valve to not close. I cleared it with the air hose and when I went to get a new gasket I was asked if I wanted the $2 or the $10 one. I asked what the difference is. Turns out the $10 one has a screen to keep big particles out of the EGR. Still a year later starts better than my 2002 Safari. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
