Wet carpets when AC on.njkid 08-15-2007, 10:44 AM I have a 1995 Intrepid that I am happy with other than one thing. When I run the AC for a while my carpets will get soaked. It is just water that should be draining out from condensation I assume. I think the drain holes are clogged. I cannot find where the drain holes are that would allow the condesation that builds up somewhere behind the dash or firewall area. Can some one point me in the right direction and a way to unclog the holes. Thanks for any advice!!!!!!!! AWP9521 08-15-2007, 10:14 PM There should be a rubber tube coming through the firewall for the HVAC drain, look below the steering rack in the area of where the AC lines run into the firewall it should be there. njkid 08-16-2007, 09:42 PM There should be a rubber tube coming through the firewall for the HVAC drain, look below the steering rack in the area of where the AC lines run into the firewall it should be there. Thanks for the info AWP9521!! I'll check it out this weekend!!!!!!!!!!!!! njkid 09-01-2007, 11:33 AM Saw where AC lines go into the firewall on passenger side. Still don't see any sign of a rubber hose. Took a mirror and even tried to look up under the firewall and still saw no hose. I have no clue where this drain hose is hidden. Anyone know exactly where it is?????? Automotive Network, Inc., Copyright ©2012
