93 Accord issuesRollinon18s 11-15-2002, 12:35 AM Hi I am new here and I need some help. My darling child (my car) is giving me problems with the wiring for the radiator and the condensor fans. I got a new motor for my condensor fan tonight, but now I see I can't just hook it up to my radiator fan cause the ends do not match. Right now there is this cute little red wire running from my rad. fan to my fuse box and it is hooked up to my ear window motor fuse. Recently it started shorting out and it keeps causing my car to die. I need to get this stuff wired right, but I am unsure as how to get my rad. fan hooked up to the relay right and i can't find my condensor fan relay even though it says it is hooked up on the left side of the engine. Can someone give me some pointers on where to start? The red wire burned itself to my ground wire and it is causing my car to run crappy. Thanks in advance!! pimpstyles77 11-15-2002, 08:50 PM you need to check the ownership mannuel you buy it at the dealership. it has al the wirring you need to know but it's hard to understand Rollinon18s 11-18-2002, 04:09 PM I found my connector for my condensor fan...so that will solve that problem. I guess my friends were to blind to find it and decided to cut wires. Now I am just hoping I can find the connector to the radiator and the short problem will be solved. jmabbott 07-27-2003, 04:57 PM Well I see that you posted your question eight months ago. This is in response to the unanswered question which someone else may need answered: 1993, Honda, Accord, LX, Where is the condenser fan relay? On the drivers side, in the engine compartment, attached to the fender, a half a foot back from the head light, kinda behind the power steering fluid reservoir, is a metal bracket that looks like an upside down letter T. It has two "broom handle" clamps. These clamps hold the condenser fan relay and the compressor relay. Both are round which is not like the square radiator fan relay inside the fuse box. They are interchangeable if you want to swap them around for troubleshooting purposes. I am glad that you figured out that someone had rigged up the wiring. The original fan motor wires are not RED. Best of luck. Automotive Network, Inc., Copyright ©2012
