Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier > Cavalier Problem Diagnosis
Old 08-15-2007, 06:46 AM   #1
kyrawe
kyrawe Normal reputation
Engine won't turover
Help! I replaced a bad water pump on my daughter's 1997 Pontiac Sunfire (2.2L engine) last night. I disconnected the battery, removed the altenator (the pump is under it), removed the old water pump and installed the new one. After installing and reassebling everything, the engine now cranks but won't quite turn over. It's really close to turning over, but won't quite make it.
Is this related to replacing the water pump? It turned over fine just prior to my replacing it. Any thoughts?
kyrawe is offline   Reply With Quote
Old 08-15-2007, 06:28 PM   #2
ChemMan
ChemMan Normal reputation
Re: Engine won't turover
I just re-read your first post. Before you do anything else, check that the battery cables are tight and no corrosion is present on the terminals.
Verify that the water pump and alternator spin freely, and then when you reinstall the drive belt, make sure you have installed it correctly. If that doesn't reveal the problem, then start looking at the battery. Good Luck.
1995 Buick Lesabre Custom 73000 miles
2002 Pontiac Sunfire SE 103000 miles
1997 Pontiac Bonneville SE 91106 miles Totaled by attempt to steal the car!!
R.I.P. 1978 Ford Fairmont 83000 miles
FTN
ChemMan is offline   Reply With Quote
Bookmarks
Google
Web AF
