***94 Accord Intermittent No-Start & Shutdown, Code 15***jfa63 08-12-2007, 02:38 PM ***94 Accord Intermittent No-Start & Shutdown, Code 15*** Intemittent no-start. Always throws code 15 (Ignition Output Signal) when it occurs. Sometimes, just shuts down quickly when running. Not a stuttering shut down, but a quick shut down. Replaced ignitor already a few weeks ago, as that fixed the same problem over a year ago after same intermittent symptoms that finally led into permanent no-start. I have also already reflowed the solder on the PGM-FI relay, as I did find cold solder joints on it. I had my daughter spray freeze spray on the ignition switch and main relay for 3 days in a row this week at 11:00am to no avail. On Friday, I while at work, I was on the phone with her when she was trying it. I also had her spray the distributor and it suddenly started. I was going to re-create that scenario yesterday, (Saturday) and as usual, it fired right up for me. It was sitting in the sun just like always and was just as hot as every other day when it wouldn't start for her. I'm wondering if the CKP sensor could have an intermittent problem. Also, the plug wires and cap and rotor are only about 1.5 years old and were purchased from Honda. Anybody have experience with these specific intermittent symptoms along with a code 15? 2001jettavr6 08-12-2007, 03:42 PM well check the inside of your rotor and rotor cap for corosion on the inside or something obstructing the spark. mpumas 08-12-2007, 08:57 PM Ignition coil may be the culprit. They have been known to cause the problem described but not the code 15 that I know of. jfa63 08-12-2007, 10:59 PM I failed to mention that it has both spark and fuel pumping to the rail as well compression when it won't start. Problem is that the car won't stay broken long enough for me get to the problem. mpumas 08-13-2007, 01:39 AM Are the fuel injectors working? There is a test to see if the ECU is pulsing the injectors. jfa63 08-13-2007, 06:19 AM Yes, it runs great when it's running, which is most of the time. I've snugged up every connector I can find and wiggled wiring harnesses, etc. It's like it fires for about 1.5 seconds, then shuts down. Automotive Network, Inc., Copyright ©2012
