1991 4X4 Problems?
innocentman1812
08-10-2007, 03:51 PM
I just picked up a 1991 Ford Ranger and it has the electronic 4 wheel drive selector. When i hit 4x4, the light beside the button lights up, and 4x4 appears near the gauges...but it will not go into 4 wheel drive, so i was wondering if there was a way to check the electronic motor on teh transfer case w/o taking it off. Also, when i click 4x4 Low it dosn't do anything...its almost like its not hooked up...any ideas on what would cause that?
scott83
08-20-2007, 01:04 AM
it probably is the electric motor that engages the 4wd.. you can crawl underneith the truck and engage the motor manually but i dont know how you do it
innocentman1812
09-05-2007, 06:43 PM
Alright, well, my electric motor is still good and turning, Is there a vaccum line or anything aswell that should be on it? or what else might it be if its not a vaccum???
nymorey
09-05-2007, 10:00 PM
Not sure about the 91 but some have a vacuum actuated mechanism that engages the hubs. It should be a big tank mine is shaped like a ball up near the headlights.
That was the problem I had. I reconnected the hose and it worked fine
