94 Accord Ex brake light indicators on dashboardirmat 08-09-2007, 12:20 AM Both the handbrake light and the abs light on the dashboard are coming off and on. usually one then the other, sometimes both at the same time. took car to mechanic and brakes checked out fine. six months ago my speedometer started jumping around, sometimes accurately displays speed then jumps to 65 and stays there for a while even though i'm going 40mph. Are all three sensors ya think? somick 08-09-2007, 01:32 PM On and off brake light may be a fault with charging system. Have it checked at the automotive stores for free. Jumping speedometer most likely is bad VSS (vehicle speed sensor). Do a search for it. Good luck, Sam Omegastorm 08-12-2007, 01:55 PM Hey i have the same year accord look under the dash on the right side you will notice a blue connecter that is not plugged up to any thing get small piece of wire about two inches plug it into both side you will be completing the circut turn your ignition key to the onr position but don't start it watch the light blink long blinks are 10 short are 1 count them up get a hayes manual and look up the error code Ex: two long blinks =20 5 short blinks =5that totals 25 then find that error code and you can go st that fixed. the error code for you're VSS i believe is 27 or 17 try it.:smokin: Automotive Network, Inc., Copyright ©2012
