Re: 99 Cirrus guages work but no lights
I'm not sure if you have fixed this problem yet, but if not... This will help.
My wife's 2000 Cirrus LXi had the EXACT same problem. The Headlights would work, the gauges worked, but there was no backlighting. I tried replacing the four bulbs in the back of the gauge cluster, checked all the fuses, and made sure the wiring and connectors were all good. I ended up taking the car to a local mechanic and he could not fix it either. So I gave in and took it to the Chrysler Dealer, They had the problem fixed in a matter of 30 mins. They said it was a "flat battery." I don't see why that would cause the problem, but it did seem to fix it.
Good Luck!
Lost
