breather filter for stillen intake???greekman 09-17-2001, 09:34 PM i just put my stillen intake in my p10 (93.5). do i need to put that breather filter on. if so, where does it go. also where is my temp gauge so i can rig it on my filter. thanks NismoPC 09-18-2001, 08:18 AM If I am not mistaken, you do not have a temp sensor on the 93.5 G20. Only the '94 and newer engines have the temp sensor on the factory air box that you have to retro fit onto the K&N cone filter. Look in the picture below of an SE-R. You will see where the smaller breather filter goes by looking in the lower right hand corner of the screen. http://se-r.net/multimedia/pictures/sentra_se-r/sean_bruce/mvc-032f.jpg I found that picture on the SE-R.net under multimedia. You probably had a hose that was connected to the AIV and to the air box that you removed when you took the air box out. The small filter goes where the hose was connected. This is quoted from the SE-R.net on installation of the breather filter: On SR20DEs from 91-93 you also need a small filter for the AIV (Air Induction Valve) to stay smog legal. The AIV is there to dump more air into the cat to keep it lit on idle and decel, by removing the OE air box you will now hear the reed inside the AIV canister. It makes a "spitting raspberrys" sound at idle and decel, it is completely normal, you never heard it before because the OE air box muffles this sound. In 94 and 95+ the AIV should be gone as Nissan improved the engine program enough that the ECU can control the engine well enough not to need the extra air (by fiddling with the mixture and timing). Hope that helps. If not go to www.se-r.net and do some research. pist 09-22-2001, 07:41 PM where does one find the smaller breather filter and what size is it... i recently bought a hiper flow "ram air system" which is basicly like the stillen filter but its open on top too... problem is that it didnt come with the smaller breather filter... i havent hooked it up yet because im sure its not good to have that hose sucking in air with no filter... can anyone help me out at all? NismoPC 09-23-2001, 05:36 PM I don't know what auto shops are near you, but Pep Boys carries breather filters. So does Advance Auto. You can also try http://www.jegs.com JEGS Online or carparts.com, JCWhitney.com, StranoParts.com. They all carry breather filters. I think the opening is 3/4". Don't know. Just measure it. greekman 09-25-2001, 12:23 AM i still haven't put my breather filter on yet. i don't have the circled part in my car. is this normal? what do i need to do? thanks http://se-r engine greekman 09-25-2001, 12:24 AM i guess i don't know how to put a picture off my hard drive in the replys. can someone tell me how. thanks NismoPC 09-25-2001, 08:24 AM Since I can't see the picture you are referring to, the 93.5 probably does not have the black box. I will assume that is what you circled in the picture. Since it was a mid-year productin vehicle, it will have some of the '93 stuff and some of the '94 stuff, so you probably do not have the AIV box on your engine. They got rid of it in '94. where does one find the smaller breather filter and what size is it... See if pist wants to buy the breather filter from you. He is looking for one. pist 10-02-2001, 11:33 PM i'll buy it... knowing what size it is would help alot too... i went to the auto parts store and the douchebag there told me his computer only listed stock breather filters and that he couldnt help me unless i wanted to go into his storage area and open boxes for an hour looking for something similar to the right size greekman 10-03-2001, 02:22 PM Originally posted by pist i'll buy it... knowing what size it is would help alot too... pist, i'll measure it tonight and get back to you. drop me an e-mail and we can work this out. what measurements are you looking for? pist 10-05-2001, 10:48 PM havent had a chance to measure yet... im workin on finding the time to pop the hood... stuff is crazy... if you want contact me on aim TIZAO 10-24-2001, 09:46 PM Any size will fit, infact I think that they are all the same. I have a 93.5 and I just did this less than a month ago, dude you do have the box. Put some lube on the end of the filter and force it in, it will fit. Just go to your local shop and they have them for like $12. GtRider 10-24-2001, 11:14 PM what exactly does a breather filter do?? does it give you more hp? TIZAO 10-24-2001, 11:40 PM Ok here it goes. The black box is originally conected to your air box, by a hose. This is constintly sucking so that you can get air into the box. When you get rid of the box, you get rid of the hose. Now you have something sucking in air all the time still, but you have no filter. The breather valve, makes it so that you are sucking in clean air, and you dont damage your car. DONT run your car without the breather valve. It doesn't add to your HP, it just makes your air cleaner. If you want more HP let me know, I have a high flow cat for cheap never used still in wrappings gives you like 15 to 20HP! Or I have exhausts for sale, this is what gives you HP for realitively cheap. The filter only gets better starts and about 2-6HP depending on what you use. IF you have any questions or are interested in anything for your car let me know. :alien: :bloated: :licker: :smoka: greekman 10-25-2001, 03:32 AM Originally posted by TIZAO Any size will fit, infact I think that they are all the same. I have a 93.5 and I just did this less than a month ago, dude you do have the box. Put some lube on the end of the filter and force it in, it will fit. Just go to your local shop and they have them for like $12. are you refering to me with regards to the box. if so, i checked and checked and checked, but still didn't find the box. as nismopc pointed out our cars are 93.5 so they have some stuff from a 93 and some from a 94. my car definitely does not have the breather box. TIZAO 10-26-2001, 02:04 PM Originally posted by greekman are you refering to me with regards to the box. if so, i checked and checked and checked, but still didn't find the box. as nismopc pointed out our cars are 93.5 so they have some stuff from a 93 and some from a 94. my car definitely does not have the breather box. What the hell? I have a 93.5 and I have a box. Whats up with yours? Do you have a pic of your engine? greekman 10-26-2001, 05:05 PM Originally posted by TIZAO What the hell? I have a 93.5 and I have a box. Whats up with yours? Do you have a pic of your engine? i know, i know. i spent hours looking for that little damn box. i don't know, but like i said our 93.5's have 93 parts and 94 parts. in 94 they got rid of that box. no pics-no digital camera. i'll try to borrow my friends and take a pic. TIZAO 10-26-2001, 11:03 PM Originally posted by greekman i know, i know. i spent hours looking for that little damn box. i don't know, but like i said our 93.5's have 93 parts and 94 parts. in 94 they got rid of that box. no pics-no digital camera. i'll try to borrow my friends and take a pic. But why would your 93.5 have no box, but my 93.5 DOES? THat makes no sence, I just have to see your pic if you get one.:alien: :bloated: :smoka: GtRider 10-26-2001, 11:07 PM i have a 94, but on that black box i dont see any where i can attach that breather to. TIZAO 10-26-2001, 11:09 PM Originally posted by GtRider i have a 94, but on that black box i dont see any where i can attach that breather to. Wait your 94 has the box? NOt the intake box, but the one infront of your engine? A380Driver 10-27-2001, 03:36 AM Guys...check out the production date of your car on the drivers side door sticker. I have a 93.5 but my production date was 1/93. Some will be later in 1993...and will have the incorporations of the 94 model year, but still sold as a 93.5. NismoPC 10-27-2001, 09:03 AM http://se-r.net/multimedia/pictures/sentra_se-r/sean_bruce/mvc-032f.jpg GTRider, If your 94 has the same setup sitting on top of the exhaust manifold as this picture shows from a previous post of mine, you do not have a 94 production engine in your car. NOTE: There are two (2) "black boxes" as everyone is stating. The AIV box which is the box we are referring to sits in front of the other box. Look at the picture closely! SO, if your engine has only one (1) that is NOT the AIV and you do NOT need a breather filter. Koojo 01-25-2002, 11:38 PM Originally posted by TIZAO Ok here it goes. The black box is originally conected to your air box, by a hose. This is constintly sucking so that you can get air into the box. When you get rid of the box Is there a 'black box' on a 2000 G20? I know that there is a hose that goes to the air box, but im not sure where it goes to, but the new Stillen Intakes and JWT intakes have a little 'nipple' nozzel for those I think. correct me if im wrong Automotive Network, Inc., Copyright ©2012
