1997 4.3litre stalls when stopping, starts right back up,fuel pump has been replaced,fuel pressure regulator,and the ignition switch and harness,whats left? 154k,and does not generate a code. up date,cleaned the MAF sensor no change,unplugged EGR valve i did generate a code no#p1406 p and p0507 p the first pertains to the EGR circuit the second is for high idle both have been corrected. It will not die just by putting it in gear, it only dies after driving and then coming to a stop.It will not die after starting and then putting in gear only after driving. Now i have installed a cam shaft position sensor same problem
