Thermostat location??Silver Blue '97 08-02-2007, 08:06 PM I have a '97 Aurora, will somebody please tell or show me where is the thermostat is located. I have owned this car for 5 years now and the normal running temp. was 200 deg., just lately it's running the next line above 200 deg. I changed the water-pump belt because it was the original belt, thinking it might be slipping, no change. I would like to change the thermostat but don't know where it is or what the procedure is. If anyone has any other thoughts on this problem I would greatly appreciate it. Thanks in advance! 3100MPFI 08-02-2007, 11:16 PM thermostat is on the engine where the upper radiator hose is attached. Here is a pic from the book. http://i174.photobucket.com/albums/w86/riven2129/c3874823.jpg Silver Blue '97 08-06-2007, 05:34 PM Thank You 3100MPFI, a picture is worth a thousand words, Thanks again! This means you have to drain the whole system, right. 3100MPFI 08-07-2007, 05:44 AM When I did it, I just drained the radiator. Well, removed the readiator. The radiator had sprung a leak, so while it was out of the car I did the thermostat. Automotive Network, Inc., Copyright ©2012
