92 Park Ave.tegger 11-11-2002, 01:16 PM Lately my 92 park ave. has been having a starting problem! When you turn the key it starts but stalls right away! I turn the key again and it starts, but tends to smell like gas for a short while! What could be the problem? Thanks tman 11-11-2002, 05:08 PM mine does something similar to that. My unlce says to tighten the bolts on the valvepan cover. KEVINS800 01-21-2003, 06:56 PM your fuel presure regulator is most likely bad!! run the engine then shut it off, then pull the vacumn hose off the fuel presure regulator. check to see if gas is comming out the vacumn line! if there is gas> then replace the fuel presure regulator. Melt 01-21-2003, 07:01 PM I also think its probably your fuel pressure regulator, friends park ave had a similar problem. tegger 01-21-2003, 08:10 PM It was a cracked short hose to the regulator. I replaced the hose, no more problems! Thanks Automotive Network, Inc., Copyright ©2012
