1999 Rav 4 Low Idle.
Google
Web AF
movieprops
08-01-2007, 05:36 PM
I just purchased a 1999 Rav 4. When I start it up ,the idle stays low, and when I turn on the A/C , the idle dosn't increase either. I know there is a sensor that is suppose to kick up the idle when the car is cold, and a sensor to kick up the A/C when it is turned on. But I don't know which sensor, or where it is located. If somebody has the answer can you help me out with this? Thanks
Yota_Fiend
10-07-2007, 09:12 PM
It actually might have nothing to do with the sensor (and the sensor your thinking about is the MAP, which detects the load on the engine and tells the PCM to adjust everything accordingly.).
The most common cause of a low idle on older toyotas is the IAC (idle air control) solenoid. It can get gunked up with carbon over time. The IAC is what controls your idle, so if its not working right, your idle will be off.
It takes maybe a whole half hour to clean it out, so even if its not the cause, its not like you wasted your life.
I dont have a link, but there is a walk-through on how to clean it somehwere on the rav4world forums (http://www.rav4world.com). you can look it up there.
Google
Web AF
