Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 08-01-2007, 12:22 PM   #1
velodyne
velodyne Normal reputation
2000 blazer accel problem
My blazer accelerates really weird, if i press like half pedal it revs up to say 2000rpm then drops to 1500rpm before reving up again but does it slowly... if i press full pedal i revs right up to like 3500rpm but doesn't really go that fasft then shifts at 5000rpm...
have all new plugs wres cleaned maf.. cat was plugged so i change whole exhaust... any ideas???
velodyne is offline   Reply With Quote
Old 08-02-2007, 11:45 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
MT-2500 Normal reputation
Re: 2000 blazer accel problem
What engine?
Any engine missfires or miss?
How is the fuel pressure?
Got any codes or check engine lights?
What kind of spark plugs did you feed it?
MT
MT-2500 is offline   Reply With Quote
Old 08-03-2007, 08:14 AM   #3
velodyne
its 4.3, i put ac delco platinum plugs and i get no codes. But i didn't check my fuel pressure. I have changed pump and fuel filter not long ago..
Old 08-03-2007, 08:46 AM   #4
MT-2500
AF - Advisor
MT-2500's Avatar
On the fuel pressure test you need more testing.
Fuel pressure specs are 60/66 on your engine.
Key on pressure is good.
But we need the engine cranking pressure.
Your engine running pressure is dropping below specs.
Engine running should range about 61-62 full vacuums no load or idle.
A throttle snap or a load on engine no vacuum the pressure should go to 65-66 range.
Steady driving down the road or light throttle it should range 63 -64.
But you need to get a fuel pressure gauge taped to the outside of windshield and drive it 30 minutes to a hr and watch the fuel pressure after the engine and fuel pump has warmed up good.
And also watch the fuel pressure when it acts up.
Like catching it in the act of acting up.
But that does not always say the fuel pump is bad.
The fuel pressure regulator controls pressure as long as the fuel pump has pressure to control.
You need to check the direct fuel pressure at the fuel filter to check pump.
It should put out 75-85 lbs of direct pressure to be good.
Also a pinch the return line of will give you a fuel pump or fuel pressure regulator check. Which should also be done after fuel pump has been run 30 minutes or more.
So before you replace the fuel pump do the full testing on it.
You could have a fuel pressure regulator problem or other problems besides the pump.
MT
MT
Bookmarks
Google
Web AF
