Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Astro > M Bodies
Old 07-30-2007, 02:13 PM   #1
HSMaxim
HSMaxim Normal reputation
96 Astro no juice to the fuel pump
Ok, I was having problems with the van starting when it was wet out. I discovered the coil was arcing and it would start after a dose of WD40.
Last week my mother borrowed it to pick up a lawn ornament thingy, I told her to not shut it off, but she decided to hit some yard sales and to save gas, shut it off.
After it wouldn't start, it was towed home on a flatbed. I replaced the coil and module and now I have spark but no fuel pump. I switched over the AC and Fuel Pump relays and using a Snap-On red brick, comfirmed that the relay was working.
Does this van have a fuel shutoff or something that disables the fuel pump in an accident? The only thing I can think of is that the roll back operator may have jarred it hard enough to cut something off.
I pulled the 4 pin connector under the van and get no voltage in any of the pins with the key in the run position.
Anyone have any suggestions before the van ends up going to the firing range?
HSMaxim is offline   Reply With Quote
Old 07-31-2007, 07:05 AM   #2
brcidd
brcidd's Avatar
brcidd Normal reputation
Re: 96 Astro no juice to the fuel pump
jumper out the fuel pump primer test lead- put 12v straight to it-- does van start? the test lead is the red wire with a plug on it hanging out of your plastic conduit near the fuse box underhood..........
Automotive A/C Engineer with:
'95 Chev 3500, 454 Dually Crew Cab- 145k miles- Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone- blown head gasket
'92 Chevy Lumina Van 3.8L 264k miles
'86 GMC S-15 - 2.8L 154k miles
'86 Buick Park Ave 3.8L 199k miles- my daily driver
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles- my high school car!!
All but the Camaro and Firebird are white....
brcidd is offline   Reply With Quote
Old 08-01-2007, 07:13 AM   #3
HSMaxim
Thanks for the suggestion, nope still no start, the fuel pump still doesn't run even with the jumper.
Any other ideas would be greatly appreciated.
Old 08-01-2007, 12:08 PM   #4
brcidd
brcidd's Avatar
with primer lead jumpered- test voltage at fuel pump- to be sure it is getting there--- if so beat on the gas tank- to see if fuel pump starts pumping- they get dead spots in them and need to be replaced when this happens........
Old 08-02-2007, 07:04 AM   #5
HSMaxim
Thanks, i'll try that as soon as I can.
Old 08-09-2007, 07:41 AM   #6
drew300
drew300 Normal reputation
In front of the tank, on a frame member, is a black ground wire for the pump.
Mine was rusted.
At least it's an easy check.
drew300 is offline   Reply With Quote
Bookmarks
Google
Web AF
