86 yoda OIL IN CARB!markstuts 07-29-2007, 09:04 PM i just bought a 86 toyota pickup with the 22r engine. I noticed it was leaking oil, upon further inspection, ifound that it is coming from the carb. I opened up the air cleaner and there was oil standing in the bottom of it ,and the filter was covered in it as well. There is a hose coming from the front of the valve cover that goes into the air cleaner. It is coming from the valve cover through that hose. I took the hose off and started the truck and there is alot of pressure coming from the valve cover. Just wondered if anybody has expereinced this. thanks, mark mikes451 07-30-2007, 04:54 PM Ive heard that a bad PCV valve can cause this type of thing so you might try changing that, its only like $5. The PCV valve is easy to change its located at the top of your valve cover. markstuts 07-31-2007, 10:44 AM Yeah, i already tried that. It didn't do anything. thanks though! fourwd1 08-08-2007, 11:19 AM There should be a baffle inside the valve cover where the hose is to help prevent that. Could be a problem there, but more than likely your engine is so worn that it's more than it can handle. Automotive Network, Inc., Copyright ©2012
