Innova
sky_high
07-28-2007, 03:16 AM
Does Any of You have or know something about Toyota Innova?
techsavy
08-25-2009, 05:55 AM
Toyota Innova is a toyota designed MPV i.e. being less than 4,600 mm (181.1 in) in length as per the European system of size classification, produced in Indonesia under supervision by Toyota Astra Motor since 2003.
More about Toyota Innova here : http://en.wikipedia.org/wiki/Toyota_Innova
caradmin
08-17-2011, 06:12 AM
Toyota Innova is the most popular MUV (Multi Utility Vehicle) in the Indian market which belongs to a breed of cars that is hardly seen in the auto market. Toyota Innova is the 5th generation of the Toyota Kijang, while its outgoing model and Toyota Qualis is two generations behind. Toyota Innova wishes to combine features like space and ruggedness associated with MUV's along with comfort and handling that is normally seen in high segment cars. Toyota Innova is an ambitious project, considering the fact that Toyota Innova is here to replace Qualis. Toyota Innova is car that showed Indian manufacturers quality work in a segment where most of the cars sold, are used as taxis. Toyota Innova can be an owners pride for its design, comfort, safety and innovative features. It features virtually the same dimensions as the previous model, but offers an all-new body with a lean, stylish shape that offers more interior and luggage room, engines that are more powerful yet more fuel-efficient and an all-new chassis and suspension.
The contemporary design of Toyota Innova emphasizes the fact that it is designed to cater to the world market. Innova offers excellent handling and drive quality with its elegant interiors, additional advanced features and generous cabin space. Toyota Innova has an excellent shape. Its wheel arches are flared and it is high enough to do away with any number speed bumps that it might encounter. Toyota Innova equipped with double wishbones with coil springs up the front suspension. On the other hand the rear suspension uses a non-independent suspension, with four links and a lateral rod with coil springs.
http://images.cardekho.com/images/carexteriorimages/medium/Toyota/ToyotaInnovaG4/121.jpgThe petrol version of Toyota Innova comes with a 1998cc, 16-Valve DOHC WTi petrol engine that produces 132PS power at 5600rpm and 181NM torque at 4000rpm while the diesel version of Toyota Innova comes with a 2494cc, 16-Valve DOHC diesel engine that produces 102PS power at 3600rpm and 200NM torque at 1400-3400rpm. The petrol variant of Toyota Innova is compatible with CNG. The CNG variant of Innova has a manual selector switch that enables the driver to easily switch from gasoline to CNG and vice versa. The CNG Innova has an on-board cylinder that has a capacity of approximately 12kg. The running cost on CNG for the Innova is estimated to be around Rs 1.6/km or less depending on the driving situation.
