Underdrive pulleysnymorey 07-27-2007, 06:06 PM I installed an underdrive pulley for my 99 3.0L Ranger with no problem. Now I want to replace the alternator pulley.... How can you get it off? The nut is obviously on there pretty good and before I start manhandling it, I'd like to know if anyone else found a good way to get it off. DonSor 07-27-2007, 09:27 PM Remove the alternator and remove the pulley using a bearing puller. Reverse procedure to install. nymorey 07-27-2007, 10:03 PM Remove the alternator and remove the pulley using a bearing puller. Reverse procedure to install. But how do I get the nut off first? DonSor 07-27-2007, 11:30 PM Apply a good penetrating lube around the thread. See if the nut will come out. Try using an impact wrench. e_powers 07-28-2007, 02:35 AM Apply a good penetrating lube around the thread. See if the nut will come out. Try using an impact wrench.+1 but if you dont have air tools a length of pipe on the handle of the wrench will help. nymorey 07-28-2007, 07:27 AM +1 but if you dont have air tools a length of pipe on the handle of the wrench will help. That will be the plan. It looks like a reverse thread, do you know if it is? jubangy 08-30-2007, 06:09 AM It should not be a reverse thread. Would be alot easier if you use an impact wrench as using a breaker bar and socket will make it a real pita to hold still while loosening. If you dont have an impact take it to a garage they should be kind enough to pop it loose for you, will only take them a second or 2. timd 04-23-2008, 01:22 PM Been nearly a year since the original post. Any updates? pros/cons? I have a 2002 Ranger w/3.0 that I'm considering putting an underdrive pulley on to increase MPG. What's your opinion? Automotive Network, Inc., Copyright ©2012
