Re: rotors for '98 Accord Coupe
If you keep warping rotors you've got a problem with drag causing heat build up, most likely. Push the pistons back with the calipers still mounted up, if you can't slide the caliper back and forth on it's slides easily with two fingers, you're dragging....
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
