Ingalls Front Upper Camber Kit Squeeks
Google
Web AF
hahakenny
07-25-2007, 04:11 PM
I had Tien Adjustable Coilovers installed on my 95 Accord and a set of front Ingall camber kits in front. Lately it's been squeeking and at first I thought that the friggin Tien shocks were bad. But later I found out that the camber kit bushings were not properly lubed. It was recently lubed a few months back and now the heat has come and the squeeking is back.
Any recommendations on what type of lube/greese I can use for this problem? Only the front driver's side squeeks for some reason. Either it dries out or something. Thanks.
http://i18.photobucket.com/albums/b125/hahakenny/CIMG2373.jpg
jeffcoslacker
07-25-2007, 06:03 PM
If they use polyurethane bushings there is a specific lube for them or they will make noise...they should have coated them during installation...after the fact the lube can't get where it needs to be (between the interference fit surfaces)
http://www.polybushings.com/pages/bushinglube.html
This is the stuff you want, though.
hahakenny
07-26-2007, 08:27 AM
Thanks. At least this will help when I get my motor swap. I will see if they can re-lube the camber kit at the same time. 6 months of quietness is better than a gradual increase in squeaking noise.
Google
Web AF
